3D 75cc 106" HyperLITE Slick 540 by Fibertech N More
Fibertech
70cc 106” HyperLITE Slick 540 by Fibertech N More
When we introduced the 100cc 42% HyperLITE earlier this year I had lots of PM’s on if there was going to be a 35% version. So this is the going to be the proto build of the 35% HyperLITE. I’m going to be using a DA70cc for the Engine with stock exhaust on this one and Savox servo’s. To save some time in the future I am going to kind of do this build as a manual format so there will be a lot of pics of detail and some video. If you haven’t fallowed any of the past builds of the 42% there is one being done know by Bipenut here on GSN http://giantscalenews.com/threads/fibertech-hyperlite-slick-540-build-thread.1447/page-2#post-33027
Also one that Terry had done: http://giantscalenews.com/threads/fibertech-hyperlite-slick-sort-of-build-thread.157/
Brads from Canada: www.rccanada.ca/rccforum/showthread.php
I also had one on the other side that I will be bringing over here soon
Specs:
Wing Span 106”
Wing Area 1999 sq.in.
Fuse Length to end of cowl 90.5”
Engine 50cc-85cc
Weight 17-19lbs
Materials:
Foam Core Balsa Sheeting
CNC Router cut parts
CNC cut Foam
Just a couple pics of the 42% to start with. The 35% will look the same just a bit smaller
After removing all the CNC cut parts and some light sanding I started with the center portion of the engine box. I’ll build the engine box complete before any glue is used. As pic 2 shows I start with TG1 and F2C 3/32”Ply paying attention to each part position. The parts will fit very tight and will need to be forced together. This is to allow very good glue joint with CA You need some light tapping with a small hammer and block to force each tab in mating part. Again this tight fit is done on purpose for a good glue joint.
Next will be the lower MB that has cut outs for throttle/choke servos.
Know the RH side of engine box.
Then the LH engine side in place
Looks awesome, it appears that you and Terry are taking over the 3D kit market! what's the price point going to be on this plane? I am assuming it will be a short kit as well?
LOL, It's all hobby for me but Rick is working hard at growing his business. Can't wait to see this come together and hope I get to see it fly this Spring!
tylerzx9r
At-a-boy Rick! Looks like I will have to add another plane build to my list! For all that hasn't seen one of Rick's planes in person, I assure you they are quality! He displayed one at our "FBI" event last year, Super awesome! This is one you should be checking out also!:big_yes:
Bipenut
OMG !!!!
Now I have to sell both Kidneys ....... :-(
This one and Terry ' s Viper
There's going to be a lot of kidney's on the market because I will have to do the same thing. I'm already building the 42%, I'm going to buy the Viper at the end of the month and now this one. At least I will have some kits to build. Keep'em coming guy's and what else is in the works, any biplanes?
