Phil.Griffin
I've been using the Tech-Aero for a couple of years now. Zero issues. I like 'em too.
What guage wire do they use?http://www.boomarc.com/en/booma-rc-opto-ignition-switch
Been running these on everything for 2 years now.![]()
I switched my 30cc over to this same arming style switch this spring and it has worked out great. I will be changing all of my gassers over to this style of switch. I also went to a tech aero for the first time this year when I built my 60cc Edge(I was a die hard opto kill & separate battery guy). The Tech Aero is working out great and I think I will be converting over to them as well.
I had one come out in the air on a 6s electric system cost a plane Not sure I'd trust it on a big plane
Bullet proof in design and functionality. Don't have to use a separate battery if you don't want to, however I use the separate battery feature for redundancy and to keep things a little more isolated. Dependable for all size motors. Very inexpensive.... My preference for all my setups.I have been using these RCXL switches. Inexpensive and I have never heard of anyone having a failure.
http://rcaircraftcomponents.com/products/rcxl-optic-gas-engine-kill-switch/
I think 18. You can get them with JR or Deans plugs.What guage wire do they use?
Was the one you had fail a deans or APP connector? I'm just asking because on my APP plug, it is a positive lock when plugged in with a noticable snap when fully engaged, it's not difficult to pull out but definitly requires effort. I put 50+ flights on it this summer with no issues.
