The spline is FUTABA correct? Same arm size on all surface servos?2" arm, 1.75" hole.
If you are using MKS servos its futaba spline.The spline is FUTABA correct? Same arm size on all surface servos?
Terry, what temps are you getting on your DA-120 post flight?
We have some of those available2" arm, 1.75" hole.
In flight I'm seeing 160-280 depending on what I'm doing fwiw. Mine is baffled and vented just like @Terryscustom but can't tell you how our tunes match up. I run a bit fat all the time by choice. I have about 3 gallons through my DA120. Falcon 29x9 prop. Weather here has been in the mid 50s to low 60s. Sea level.Terry, what temps are you getting on your DA-120 post flight?
Jeff and my friend, Butch, just went from stock mufflers to tune pipes without cutting exhaust vents for them... he went from shooting it on the ground with a gun at 135f to 300f. He felt pretty irreverent, I guess.![]()
Hi Terry, how did you manage to get the servos in the elevator stab? Even if I could get them in, how would I tighten the servo arm lock screw?Thanks, I'm not spending a ton of time editing video, just shooting from the hip. Hope it helps people who have questions....and maybe you can pick up a few ideas as well.
Elevator setup.....
