I was fartin around with my mill and got the head out of square. I didn't really have a good way to tram it, so I made one and it's a good thing I did. It was off a bit.
Ok it took awhile but I eventually got it to work. This is the new JR DMSS system. If your servos are XBUS compatible and 2K you can with the servo programmer program the the two servos on one surface to be aligned and does it for every degree of travel. Very nice system and works flawlessly. Did my ailerons, elevators and two rudder servos.
I was at Harbor Freight yesterday looking at their grinder stand, $69. My 6" grinder is sitting on the floor, when I need to use it I set it on a stool, need to get it mounted.
