Laid out a perpendicular bisector on top of the bench with a large compass, the plane was aligned to the line and vertically plumbed. The tube supports plates were drilled together so that they are same height. A short piece of socket was laid up with carbon powder added to reduce friction, this was vacuum bagged so it is a good fit. The socket is glassed to the rear former with yarn harvested from 40 ounce glass cloth. Picked up this tip over at RC Scale Builder, the author used this heavy yarn to install formers in glass fuselage. after this cures the bottom of the socket will get the same treatment then the socket will have a piece of carbon fiber vacuum bagged over it to the former. The rear former is removable, it currently has 4 - 3/16" dowel pins and will have 4-40 screws once completed.
