This is always a important or anxious time for me. Potting the wing saddle and making sure you have not glued the wing and the hold down screws to the fuselage. And you will only know 8 hours from now if you did everything correctly. Also at the same time I did the stabilizer had enough epoxy left over so did it at the same time, I thought let’s go for it all or nothing.
Been working on this little flying wing called the micro DammitE from AngelWing Designs. I’ve seen some people rattle can glider frames and cover with clear covering. I decided this little frame would be a good test subject. It’s a rustoleum fluorescent pink and yellow that when sprayed wet makes a cool orange gradient. I’m quite pleased. Just waiting on some electronics. I’ve got quite a gaggle of little gliders and I’m thinking about getting a separate transmitter for them that’s more spur of the moment portable like a radiomaster zorro…
View attachment 123372 View attachment 123370 View attachment 123371 View attachment 123373
That’s a pretty cool idea. Mikey like. 👍
Like the idea never thought of doing that have to think about that. I do like it. Wonder how well you can see when it is up in the sky.
