BalsaDust
So as I have talked about in another thread I have been working on designing a 20cc sized Giles 202 profile. The goal is to have a profile that will still perform well at low and slow like most all slabs like to do but I want it the wind up tight and carry energy unlike a normal slab. Most if you try to do a poptop will barely get 1 rotation at the top before you have to fly out of it. I have taken what I have learned from a couple other buddies designs and the edge profile that I helped design to get here. It will have airfoiled ailerons not flat plate like most profile. Decided to go this route for strength. Even though I know its going to be more work building the wing with them in the long run it will be worth to not have an aileron that is flexing and twisting under the load of higher energy flying. Originally I had a buddy draw up the wing for me in DevWing so he gets credit for that and I just recently learned CAD. Before I was drawing it up on paper but now that I have this awesome program at my disposal why not use it.
Here are the specs.
Wing span 62-5/8"
Lentgh 56"
Wing area is just shy of 1000 sq in
Wings will be removable with 3/4" and 3/8" tubes in it
1/2" thick fuse
DLE 20 on the nose
Solar 771's all around for the time being as its all I have on hand.
Here are the specs.
Wing span 62-5/8"
Lentgh 56"
1/2" thick fuse
DLE 20 on the nose
