OK guy's here we go, lets start with an equipment list, this will provide the exact components used to build the Carbon EDGE.
1) Pilot RC 30% EDGE 540 airframe
2) DA60 Engine & Ignition
3) DA Header, 1.25" drop, Prowflow medium size canister
4) Blazing star 1.25" engine mount
5) 4titude 16 oz. gas and smoke tank
6) Sullivan skywriter smoke pump
7) Redwing RC "orange" power box
8) 4- 2700MAH (7.4 volt) 2 cell Fromeco batteries
9) Taildragger RC single rudder tray (carbon fiber)
10) Redwing RC carbon fiber servo arms and aluminum spools
11) Smartfly Ignition voltage regulator
12) 5- Hitec HS7954SH servos for control surfaces
13) 1-Hitec HS635HB throttle servo
14) spot on 4" "flywheelz" aluminum hub wheels
15) 2- "Miracle" 2 switch / with fuel dot
16) 24X9 Carbon Fiber Prop (Redwing RC)
This is a good start, there are some other trinkets along the way that I'll provide info for.
