PoncioPilot
Hi Guys... I got for Sale all the setup from my 30CC airplane... This is a REAL GOOD DEAL... I spend close to 700$ in all this and I only used it for no more than 5 flights. You only need an Airframe and Go Up with this opportunity. Here is the description:
1- DLE 35RAcc engine. - Retail is 300$ something
2- A pair of Xoar props 19x6 and 20x6 - Retail is 25$ each
3- 3" Carbon Fiber Spinner, back plate and Bolt from Redwing - Retail is 57$
4- Tech-Aero BEC and Kill Switch - Retail is 44$
5- On Board Tachometer - Retail is 15$
6- 4 Servos for Ailerons and Elevators COMMON SENSE 7955 / 300 onz of Torq.... All servos comes with Futaba Servo ARM 1.5" - Retail is 59$ Each + the Servo Arm.
7- Align HV815 Servo for Rudder With 3.5" Double Servo ARM - Retail is 125$
8- Fuel Filter - Retail is 7$
9- 25% Scale Pilot - Retail is 32$
10- Turnigy Smoke Pump + Check valve included - Retail is 25$
11- Fortitude 16onz Fuel Tank - Retail is 26$
12- Aluminium Fuel Dot - Retail is 17$
13- Zippy 2.1 (2100mAh) Life Battery. - Retail is 28$
475$ for everything.. you just need the airplane kit...
