ryan_m
Are you losing servo control when this happens too?
Mine is setup this exact same way, except I now have digital 5085's and still on the Ice internal BEC with no problems. I did take care to make certain my servos aren't trying to force the control surface past the stop point and causing a binding and current spike though.
I have mine set for current insensitive, medium timing, pwm of 12, low voltage on battery down to 4.0v (not 4/cell, but custom to 4.0), essentially trying to disable the low voltage cut, and also using fixed throttle endpoints. The fixed endpoints will require you to program your throttle endpoints, which is easy and takes a few minutes. There is a procedure on Castle's website for doing it in the technical documents. There are also youtube videos that show it.
