So another 4 packs on it this morning. I really need to do better with a timer or installing the tm1000 as I ran out of juice on one flight, luckily I had room and was landing anyway. Wound up just nosing it over a little harder than I would have liked. Cracked the cowl a little while I was changing batteries with my big hands, whoops.
Only issue I'm having is the rudder hs-65mg seems to be really slow compared to ailerons and elevator. Also after doing a few inverted flat spins, yeah they were on purpose
I seemed to have had a whole lot of left rudder when running into a vertical up line. Going to check the pull pull cable and setup to make sure it's not the issue. Didn't have time at the field as it was on the last pack and when I was coming in to land ans flew the pattern, it seemed to be responding normally.
Any advice?
