I use zip ties. Easy enough to cut if you need to.
Cool, thanks. What power system do you have in yours? Batteries?
I am running the Omega 130g on 3s 2200 packs on a Castle Ice Lite 50. Hitec 65MGs all around, but I am going to swap those out for Savox 0255MGs on the new airframe.
My only complaint with this airframe is that the elevator has some flex to it. I taped it up with clear packing tape and it made a big difference. I also think that I am getting some blow back on the 65MG at the elevator which is why I am swaping over to the Savox. I had a fiberglass control arm extension on the elevator at one point but took that off first thing when I felt the flex in the elevator, I noticed some difference with the stock arm but the tape on the control surface is really what seemed to make the difference.
If you choose to tape yours the best way to get it to stick is to take some of that 3M spray adhesive and apply that first and then apply the tape. The packing tape doesn't stick to EPP very well on its own.
Also, be carefuel when your gluing with regular CA or welders on this airframe. It has Depron sandwiched between the EPP in some places. If you hinge your control surfaces with regular CA it will melt that Depron that is sandwhiched between the EPP sheets.
I really think you might be on the heavy side with the 2600 in this airframe, but then again I don't know much about the motrofly you have so maybe it puts our more power than the Omega. I feel like mine is heavy in the hover with the 3s 2200s. You might borrow a 2200 from someone and see if you like that better. The heaviness issue is the only reason I am getting a new one. I had to rebuild the motorbox in my current one and the little bit of extra weight really affected the punch out power.
As far as flight time goes I have my timer set at 5 minutes w timer starting at 25% throttle in the DX8. Below 25% throttle the timer does not run. My batteries typically come down at 30% of charge capacity.
The motrolfly is a few grams lighter than the Omega, and the 2600s I got are 215g, pretty close to many 3s2200 packs in weight to I figured I'd be ok. 5 minutes and 30% sounds perfect for me. At some point, I may setup telemetry.
-G
Sweet! Let me know what you think about the punch out power on that Motorfly. I am not opposed to jerking out the Omega and putting it in something else if they Motrofly is better.
