Yowzilla
I had to read your process a few times but think I have it. The part that took me a second to get was, you are putting the modified 4-40 threaded rod into the wing tip hole where the blind nut should be. With the string from wing tip hole to root of wing, you can simply place the blind nut onto the 4-40 threaded rod you made and simply pull it into place...good stuff.
Thanks!!!
Thanks!!!
