Ill fix it myself as long as the windings aren't toasted at all. I didn't notice the problem in flight so that has me hoping I caught it in time.
I may put a 20x8 on again. I think the motor would like it ok now. Its hard to argue with how its flying with a 19x8 right now though. Its fairly ballistic and my slick is no longer real light. There is lots of epoxy and extra wood now
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I'm guessing the EF 78 xtra is a similar weight.
Brigg was flying micros. We have not finished the yak that is getting the dle 55. It is being re-covered. When I stripped the covering I found several areas that need structural repairs.
I am running 32:1 and don't plan on changing it... ever. It is really pulling hard and I see no reason to thin it out... I'm happy with the power. Here is the part where you might laugh though. I am just running cheap walmart ashless oil. It is a synthetic blend for outboard boat motors. I have run expensive oils before and feel this is working just as well. So if you are the type that has to run expensive premium oil I suppose you won't take my lead
It has been working well for me though so far with over two gallons through the motor. I suppose time will tell. I certainly don't baby the motor or plane while I'm flying though. Plenty of violent things mixed with extended hovering etc.
Btw. I'm guess I'm seeing similar power right now to what you will be getting after half a gallon with your bowman ring. It is pulling really hard.. Id say at least 10% more power now than when new. Its very noticeable. I think you are going to enjoy it
