The older 6014FS recievers had problems with some servos. The newer 6014HS reciever addressed that problem
Believe it or not Futaba recommends Smart Fly. All of my large planes use the expander pro. All equipped with R6014HS receivers. I Tested 3 of the RCCSKJ boards and all three failed vibration, and voltage tests. Two would not hold the voltage setting dialed in and one would keep cutting out the ignition voltage. VERY risky board. I know they have several models (Four I think) but the three I tested were the top of the line.
Why Futaba recommends Smart Fly or Other "similar" board you ask???
Because it buffers and boosts the receiver signal voltage from 3vdc to 5vdc.
Some servos analog or digital will freak out on 3vdc signal. It also aids in the use of long servo extensions which are necessary in the big boyz.
