3dmike
thanks charlie and yes it all helps bud.
take a look at the deal of the day! Might help you out since your looking at servos!
Wouldn't it be better to keep them all digital. So maybe run the HS-5065MG in place of the 65mg's plus the digi's are 11.91 grams vs 12.47 on the 65mg's. Torque is the same on each @ 6V. Speed on the 65mg is 0.11 sec @ 60 deg...5065MG is 0.11 doesn't say if it's at 60 deg or not...both at 6V. So when you say comparable those may work? Or does it matter if you mix digital with analog on a spektrum setup?
LOL isn't learning fun...![]()
