The final weight is up to the engine and a few other things. With the Valach 210 the weight is
inclusive 1,5 Liters of smoke oil and 1,0 Liters of gasoline max 25 kg. We have to
reach this weight mark because of the restrictions in Germany. Every Modell Airplane which has a
higher weight than 25 kg. we have to to a Registration.
We do not know the exact weight of the lightest Version ( with a lot of parts in carbon
instead the Standard kit parts ) bit it will be aprox. 0,5- to 0,8 kilograms lighter.
The Aircraft is constructed for unlimited aerobatic flight. We don´t have a g-meter in
the Prototype to test the loads on the "hard" testflights but we will do that.
The final construction for the final Kit EAGLE we want to test with a max load of 12-15 g´s !!
Therefore the Modell aircraft is loaded with aprox. 300 kg´s on the wings.
The Airspeed of the 50% Eagle ( V-max ) 187 km/h -> aprox 105 knots the Speed of the 100% Eagle is max 210 knots
The minimal airspeed ( measured at touchdown Point at landing ) is 50 km/h -> aprox 28 knots (100% Eagle v-min 58 knots )
You can see - ist nearly exactly 50% .
To assemble the Eagle on the field takes 20 minutes ( if nobody stands around you and talks with you...
We tested it several times, but if every part is done with concentration and finally checked
it takes always 20 min. inkl. fuel and smoke oil filling.
OK - today we did a turtledeck in the final mould - will see tomorrow
the the result.
Thomas
