Finally!!!! My Edge is ready for maiden tomorrow!! Had to buy new batteries as the ones I had (4000mAH packs) had puffed, and, I also needed more weight in the nose, so, went with new 4S 45C 4400mAH Thunder Power packs. And.... I ran up the motor today for the first time. On 8S with a Hacker A60-5S (295KV), I got 2335 watts @ 79.35 amps, using a Xoar 20X10 Carbon fiber wide "gas" prop. Some might think this low on wattage, but this is a 28 pole motor, and you can't compare input watts of a 28 pole motor to those of a 14 pole motor such as an A50-14L or a Motrolfly motor. While I didn't check the thrust with a fish scale or anything, but I can tell you, when I had the stab pulling against the back of my ankles, it hurt, and I haven't even set my ESC yet!!!
SteveT
