AtomicFlyer
Looks awesome Marc, congrats!
Thanks for everyone's help along the way. I appreciate it.
Marc
Marc-
nice build but a couple pointers.
1. The miracle switch is a ticking time bomb. I had one break in my hand during installation and seen 2 planes go in due to switch failures. Get yourself a better switch (Fromco Badger or wolverine) or go to radio shack and get a new toggle switch (~$5) and solder it in place of the OEM on the miracle switch.
2. The brass fuel lines need to have barbs on them, use these http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWH38&P=7. Without them the fuel lines will work themselves off and it will happen in the worst time. Solder them on your brass lines, take a look at your cluncks for “how they should install”.
3. Those steal lines will eventually eat through the fuel tubing (my personal experience). I use zip ties everywhere.
4. For the wires (servos or switches) that are running throughout the plane, I encase them in the Expandable Mesh Sleeving, http://www.mcmaster.com/#standard-cable-sleeving/=q4jdwb. Without them the wires will eventually chafe from rubbing against the “razor” like wood edges.
Good Luck
Hosam
Help me please because I've never used this stuff before.
Which mesh for servo wires and which size coil stuff for ignition wire?
I just sent my ignition module back to DA due to chaffing from just a few flights
Craig.
