Aerobeez 38" EPP Slick 540 Build Thread!
Xpress
I would agree with [MENTION=2902]Bloosee[/MENTION], a prop like that might be too steep of a pitch to perform well with such a small and light 3D airplane.
The SF props tend to spool quicker in the low and mid range while giving you smoother thrust output. A standard thin electric prop won't bite as hard until it's into the RPM's which might make your airplane a little bit sensitive on the throttle. But always try out a few different prop choices to see what you like.
Bloosee
It goes like stink on the thin electric but it does much better 3D with the SF, much better low RPM thrust, which is what [MENTION=3822]Xpress[/MENTION] was alluding to.
3dmike
Ummmmm I'm not sure how to say this other than man I screwed up big time.
This plane lasted about 10 seconds in the air because of a dumb dumb dumb mistake. Ugggg make sure your ailerons aren't reversed!
3dmike
I fixed the motor box and I'm sure I can get a cowl from Aerobeez cheap. I would have flown it again after piecing it back together but then I realized a servo was stripped!
Bipenut53
[MENTION=2643]3DMIKE[/MENTION] I have done the exact same thing on a 50cc plane last year.... completely destroyed that plane on its maiden flight.... I almost got out of the hobby after that lol... I had no one to blame but myself.... You can be darn sure I check that EVERY flight now lol
Xpress
Dude that sucks!!!!!!
I've done it before too. Nothing destroys your ego faster than reversed ailerons on a maiden flight :scaredchair:
3dmike
Yep!!! It was a very embarassing moment... just ask @BBCorvette18! LOL He saw the whole thing! I will say that man with my setup it is a rocket!!! Rocket right into the ground!
