3dmike
Here's the Aerobeez 48" Extra 330 that we have all come to love and now in a couple new schemes!
Description:
When it comes to 3D aerobatic performance, Extra never disappoints. So we decided to put this aerobatic model on our EPP airframe with a full fuse plywood construction and give it our personal tweak. The result is a feather light, yet durable 3D machine that will take you to a whole new level of 3D flights.
This model will be your everyday 3D trainer, something you could take with you wherever you go. Yet it will provide you with the capability to practice moves that normally only bigger planes can handle. If you are new to 3D flying this will get you ready for something bigger in a lot less time.
However, you don't have to be a hardcore 3D pilot to enjoy this plane. This plane can be as mild as you want it to be. Just dial down the throws and add some expo and it would fly like a trainer with very smooth responses. You can also set up dual rates to switch back and forth sport and 3D flyings according to your mood.
We have gone through multiple prototypes before final production to ensure the plane would provide the best performance in any flight envelop.
Aerobeez owns the design rights and is the exclusive distributor of this model.
It's been a long wait and it's finally coming. Are you ready?
Schemes:
Purple: https://aerobeez.com/48-Extra-330-EPP-Full-Fuse-Electric-Aerobatic-RC-Plane-Purple.html
Blue: https://aerobeez.com/48-Extra-330-EPP-Full-Fuse-Electric-Aerobatic-RC-Plane-Blue.html
Specifications:
Wingspan: 48"
Length: 48"
Wing area: 496 sq.in
Flying weight: 40oz-45oz
Required Parts & Specs:
Motor: Power: 450W - 500W | kV: 800kV-1000kV | Weight: 130g - 170g
ESC: 40A continuous with 60A burst.
Battery: 3S 2200mAh - 2650mAh or 4S 2200mAh - 2650mAh
Propeller: 13 x 6.5 for 3s, 12 x 6 for 4s
Spinner size: 2.25"(Included)
Serovs: 14g - 20g with 1.8Kg.cm - 2.2Kg.cm torgue, ie. HS-65MG or anything equivalent in size and torque.
Recommended setup:
Motor: Hacker A30-14L V3 or Motrofly 2820-950
Speed Controller: Hacker X-55-SB-Pro
Servos: Hitec HS-5065MG or HS-65MG
Battery: 3S 2200 mAh - 2650mAh
Prop: APC 13 x 6.5
Video:
[video=youtube;QmkIdAE06go]https://www.youtube.com/watch?v=QmkIdAE06go[/video]
Detailed Pics:
Purple Scheme:
Blue Scheme:
