Aerobeez 88" Slick 540 v2 (50cc)
also, what is that sleeve material called that is black in this picture? uploadfromtaptalk1397626386221.jpg
Sleeve material is commonly called snakeskin.
I'm pretty sure [MENTION=2215]Aerobeez[/MENTION] can chime in with an inexpensive 7.4 throttle servo recommendation...
Obviously I recommend the Hitec HS-5665MH as one of the best throttle servos on he market.
Another good servo on a budget is the Savox 0220mg.
Aerobeez
Thanks Gyro. We do have an XQ-Power servo that would make a good throttle servo. for 7.4V you could go with the 4113D
http://aerobeez.com/XQ-POWER-HIGH-VOLTAGE-DIGITAL-SERVO-12KG-CM-56G-XQ-S4113D.html
For non HV set-up you could go with the XQ-Power servo 4013D
http://aerobeez.com/XQ-POWER-DIGITAL-SERVO-13KG-CM-56G-XQ-S4013D.html
Both are available on our site and are under $40.
Hope this helps in your decision.
Team Aerobeez
I think I will get the Savox 0220mg. Who carries the 'snakeskin'? [MENTION=2215]Aerobeez[/MENTION], when will the black 50cc slick be back in stock?
Aerobeez
As of right now, we do not have an ETA on a return of the 50cc Slick in the Red and Black. So the only option is the Green and White for the foreseeable future, at least for now.
Thank you,
Aerobeez
Aerobeez
If you are still in the market for the Slick 540, we just list an open box kit missing wheel pants in our bargain bin section. This item will be sold as is at a nice discount right now. Check it out here: http://aerobeez.com/88-30-Slick-540-50cc-Gas-Gen-2-ARF-RC-Airplane-Green-Open-Box.html
We also still have a few more of the Green not in the bargain bin, but they wont last long with the October sale.
Regards,
Team Aerobeez
