Aerobeez
Step 17: Lightly press fit the blind nuts into the landing gear fiberglass wheel spats. When you tighten the spats to the landing gear, the blind nuts will self tighten to the wheel spats. Note: Be sure to notice the angle on the carbon fiber landing gear. The forward sweep angle is to be installed towards the nose of the Yak55.
Step 18: Wheel spats installed.
Step 19: Use Blue Thread lock on the set screws for all wheel collars before installing. Using one wheel collar on each side, install the main landing gear wheels.
Step 20: Test fit the landing gear to the fuselage with the 4 hex screws.
