In stead of looking at the amps and amp spikes look. at your voltage. If like you said you have good set of batteries in the plane and sized properly then no matter what you do flying your voltage should not drop below the threshold. We have to admit that the only thing that will put us in to trouble is when the voltage drops low enough so that the receiver stops and then tries to reboot.Finally got to installing the new ignition this morning. With the elogger hooked up to the lap top and running on live mode I hit the heads with some hot air and the temps went up, pulled the trigger on the drill and waa laa I have rpm movement. So this rainy weather has gave me the time to improve the power supply, install the elogger, and switch out the ignition. Looking forward to tomorrows trip to the field.
As for all that technical jargon, if I can't see it or measure it I can't do anyhing about it. Or can I? Of course I can. I can ensure there is ample power supply, I can ensure the battery is in excellent health, I can ensure all connections are tight and corrosion free, I can keep track of flight time's and power used, and I can take the proper course of action if any of these items appear to be giving way in the slightest. The elogger may not be able to give me the spikes but it can give me the overall picture and as long as that picture remains the same from flight to flight along with the aforementioned I think I'll be alright.
I agree with you on all your points @49dimes but What I was trying to explain is that everybody is stating that the connectors are rated at 5 amps and the only thing that will make them fail is a certain amount of power over a period time Short amp spikes of milli seconds will not destroy the connector and put us in the ground
