3dmike
Guys check out this new Airframe from Aeroworks! Wow this is a looker and sure to be an awesome performer! This is due to arrive in the next 3 weeks so get your order in now!!!
Link: http://www.aero-works.net/product/150cc-yak-55m-arf-qb/
[h=2]150cc Yak 55M ARF QB[/h]Aeroworks is proud to add the 150cc Yak 55M ARF QB to their line of Quick Build Series Aircraft. The Quick Build (QB) Series is top quality in both design and performance that has set a new standard for ARF aircraft. Designed with the customer in mind to provide the highest quality, light weight construction and fastest build time possible.
The 150cc Yak 55M was designed to be the best looking and best performing Yak to date. This aircraft requires minimal mixing and aileron differential creating the truest flying Yak EVER! The Yak 55M has unbeatable stability and precision flight characteristics and is certain to please both the beginner as well as the advanced competitor. Designed for both Precision and 3D Style flying this plane is sure to out perform all other aircraft.
FEATURING
Strong Light Weight Construction
Professionally Covered in Ultracoteâ„¢
Pre-Mounted and Tinted Canopy Hatch Assembly
Pre-Mounted Fiberglass Cowl and Wheel Spats
Flush Fit Cowling with No External Mounting Bolts
Canister and Pipe Ready
Pre-Installed Engine Baffling
Pre-Installed and Fuel Proofed Engine Box
Laser Marked Firewall for DA and DLE Engines
Universal Engine Mounting Template Provided
Two Servo Wing
One Servo Elevator
Carbon Reinforced Wing Spar Increases Wing Strength
Large Control Surfaces Beveled for Maximum Throw
Pre-Installed Slot Style Hinges
Carbon Fiber Wing Tube
Carbon Fiber Stab Tubes
Carbon Fiber Landing Gear
Carbon Fiber Tail Wheel
Complete High Quality SAE Hardware Package Included
Adjustable Pushrods with Centering Nut
Complete and Detailed Instruction Manual
12 to 14 Hours Assembly Time
Optional Accessories:
Dash Panel
Wing and Stab Bag Set
SPECIFICATIONS
Wing Span 122 Inches
Wing Area 2775 Square Inches
Fuselage Length 109.5 Inches (Rudder to Front of Cowl)
Fuselage Length 115.5 Inches (Rudder to Front of Spinner)
Cowl Width 14 Inches
Weight 38 to 40 Pounds
Engine 150cc-200cc Gas
Spinner Size 5 Inches
Radio 6 Channels Minimum
Recommended Servos:
Throttle: Hitec HS-5625MG
Aileron: Hitec HS-7955TG (Quantity 4)
Elevator: Hitec HS-7955TG (Quantity 2)
Rudder: Hitec HS-7955TG (Quantity 3)
*See Manual for Minimum Operating Speed - Torque Output
