AKNick
Starting up a Generic Build Thread for the AJ 73" 230z Laser.
A Little About the Aircraft:
Dimensions: 73" Wingspan & 70" Fuselage
Powerplant: 30-40cc or 2500 Watt w/100-120 Amp ESC w/8s 4400mAh LiPo
OAW: 10-11lbs (Gas DA35 10lb 9oz empty, 11lbs 2oz with 12oz fuel, Electric 9lbs 1/2oz empty, 10lb 7.5oz w/3300 8s)
CG: 127 mm (5 inch) to 143 mm (5 5/8 inch). From the LE by the wing root (CG roughly 1" in front of the wing tube)
Box Dimensions: 67X21X11
Servo Arm Sizes: 1.25" Aileron, 1.5" Elevator, 3" Rudder Pull-Pull
Andrew Jesky Aircraft Website:
http://www.aj-aircraft.com/73-Laser-230z_p_9.html
AJ 73" Laser Assembly Instructions:
http://www.aj-aircraft.com/assets/images/Downloads/AJ Aircraft 73 inch Laser.pdf
I'll be going through this build as if it was for a "first time gasser" so plenty of pictures and comments throughout. SupaTim has already done a fantastic job with a completed AJ 73" w/DLE35RA on this website, I just simply wanted to make a "just for fun" open invitation build thread for this wonderful 3D Beast.
Here is a fun video I made:
