Bipenut53
Well look, here is another new offering from Spektrum. For those of you interested in gyro's stabilizing your flight, you can now have a AS3X system in any of your airplanes that has been so successful in little foamy UMX airplanes and choice other airframes, mainly foamy's but with more advanced program ability should you choose.
Key Features
Works with most any manufacturer's receiver
Ideal for everything from .40-size sport models to giant-scale aircraft and jets
Can be used with or without the free programming app
Multiple input/output connections for individual servos
Also supports standard PPM and Spektrumâ„¢ SRXL serial inputs
All aluminum case
Overview
Whether they own a Spektrum™ transmitter or not, pilots everywhere can now transform their flying experience with the enhanced stability and precision that only AS3X® technology can provide.
App or No App, It's Ready to Go
The Alpha-6™ Stability Box comes with basic stability settings already programmed. A free programming app for mobile devices and PCs will be available should you want to tailor these settings or tap into advanced functions. But you won’t need the programming app to start enjoying the benefits of AS3X technology right away.
Without the app, all you have to do is install the unit as directed and plug it in between your receiver and servos. Once you’ve assigned a channel for making gain adjustments and completed the simple setup procedure to establish orientation, you’re ready to go.
Supports Standard PPM and Spektrum SRXL Serial Inputs
The unit comes with individual input/output connections for multiple servos. If, however, you own a receiver with PPM capabilities or a Spektrum receiver with SRXL output, you can run all your input channels to the box through a single connector.
Free Programming App
The free Alpha-6 programming app will make it easy to fine tune stability settings or access other advanced features. Versions for PC and iOS or Android mobile devices will be available.
Key Features
All aluminum case
Overview
