WMcNabb
Simple question for the groups' consideration...
In the full scale aviation world, minimum safe altitudes are defined for aircraft and helicopters under FAR Part 91. If you will allow me to paraphrase....with the exception of takeoff and landing, the minimum altitude in a congested area is 1,000 ft above the highest obstacle within a 2,000 ft horizontal distance. In other than congested, the minimum is 500 ft above and 500 ft horizontal. Additionally, airspeed is limited to 250 kts. below 10,ooo ft.
This seems to open an envelope of airspace which is not governed by the FAA and should not conflict with full scale aircraft.
If the above makes sense, then why would anyone propose a private pilot's license as a requirement to operate a multirotor, commercially or not? Would it not be possible to complete a filming mission within a confined space?
Also common sense and self certification apply to full scale which presents greater risk than aero modeling - giant scale, multirotor, FPV, turbine, etc., and certainly should be applicable here as well.
