Was going to post this last night but admin was busy adding more Awesome to this site so I went ahead and anodized the muffler and posting continues tonight.
Picking up where I left off.... Cleaning, cleaning, cleaning.....
As you can tell the muffler was used. (flyin4fun mentions this above.) It is obvious if the muffler was new it may be slightly easier to clean, however even if the muffler is brand new, something as small as a fingerprint will show up in the final product so no cleaning steps should be omitted.
I started by cleaning the part with aluminum brightener then soap and water. I wanted to be sure no oil residue, dirt, fingerprints, etc.. was on the part. Next I soaked the part in a de-smut bath for 10 minutes mixed as per instructions (8:1 raito).
After my 1st part I started using the de-Smut and really liked the results.
I wanted to point out something, In the pictures you will see I took some closeups of the part prior to placing in the anodizing bath. Notice the dark spots around all the weld joints in the muffler? Anodizing mostly works on aluminum and titanium. What ever welding medium used to join the muffler together contained metal other than aluminum or titanium, (It is pretty common for welding rods to contain a mixture of other metals.) which you will see later this area did not anodize. I knew this would be the case however most of the muffler is hidden by the cowling so it was no concern to me.
Also the finish of the muffler was what I would consider very rough, what ever finish is on the part (polished, fine machined, matte, or rough) will be the finish of the anodizing when complete.
Moving on... While the part was in the De-Smut bath I began setting up the anodizing tank. The tank consist of a plastic tupperware container, 2 pieces of aluminum sheet (cathode), aluminum wire and a 3:1 raito Water/sulfuric acid. (Battery Acid) The acid is some nasty stuff. The safest way to mix this bath is to add Acid to the water not Water to Acid. I let the bath sit for about 30 minutes then stirred it up a bit to make sure it was a solution.
For power supply I purchased a chinkinizze unit for 70 bucks off amazon. It works great so far however it maxes out at 5 amps, as long as I am not anodizing anything larger than 60-70 sq. inches in surface area it will work fine. (You will see picks of the power supply in the latter steps.)
