Since your looking to use a drill motor to spin it, I suggest simply taking an old spark plug, open the gap up and orientate the plug (hold it over where you want to see the marks) so that the spark light points toward your timing marks (of course the plug will need to be installed in the boot), dim the lights, turn ignition on and spin. You should get enough light from the spark with the lights dimmed way down (might even need to be near dark) that you will be able to see the marks. This is how my method works, though I have a test stand built specifically for different types of ignitions/distributers with an adjustable gap. The spark is pretty weak on these rc ignitions, so it will probably need to be pretty dark, but it does work. And accurately.
