You can view the page at http://www.3drcforums.com/content.php?162-75-MXS-from-Aerobeez-First-weekend-in-the-air
It is slightly heavier that some of the comparable sized 3dhs planes. I am still playing with what size lipos to run in it and that will have a lot a effect on the float...etc. Right now with the heavier 4s 5000mah packs it carries a lot of speed and makes for really nice high speed tumbles and violence since, I assume, the additional weight helps it carry through the maneuver better. I have noticed that with 4s 4000mah packs it is a lighter flying plane, as expected. It does have a lot of the same flying character than my EF 48" mxs has, IMO. Obviously it "fly's bigger" but I would not consider it a floaty plane, but violent it is!
Thanks for the info., and write-up. It looks like a fun airframe, and I love the design/color scheme. If they run it on sale again, I'll pick one up and use a gasser in it.
http://www.3drcforums.com/showthread.php?734-Black-Friday-Time!!!!!&p=13839#post13839
This might be of interest to ya
Nahh, Just a coincidence with good timing
Been planning the sale for a while
