Trim the plane at full throttle and I believe that will cure a lot of things.
If that doesn't work, add some lead to the nose. Sometimes they just come out tail heavy, especially if you are running an HS85MG on the elevator. I balance mine so that they drop a little when I roll them over, and I trim it at full throttle. The 45 degree method is more precise, but I like to get it close and move the pack around until I get a really smokin' flight. Then I mark the spot on the tray with a sharpie.
[video=vimeo;115548845]https://vimeo.com/115548845[/video]
Please check out my
Video Showcase: 48" and 60" Edge EXP Bonanza
