Assembly log. EF 104 Extra.
3dbandit
Hey guys,
I began putting my extra together a few days ago, all i have done is put it on it's legs and hinge the elevators.
I will begin posting pictures later today.
Setup:
JR 8911HV's all the way around. 4 per wing, 2 on the elevators, and 1 on the rudder. hitec 7954 on throtle, jr 821 hv on choke.
JR 922 power safe receiver.
SWB 2 inch servo arms all around.
DA 120 on standard mufflers.
Smart-fly regulated opto kill.
Mejzlik 27x12TH
I will be running thunder power lipo batteries. I will choose the size later on when I am doing the CG.
3dbandit
fully deflected elevators and the components.
couldn't you get any more elevator throw than that?! (very, very sarcastic!)
Looks good so far!
3dbandit
I began hinging the rudder, i did the stab side 30 minutes ago.
to keep glue from getting in the hinges i used an oil called slippery balls, it is usually used on bearings.
3dbandit
hinged the ruder side. It is now permanently attached with bvm v-poxy.
I was able to achieve the proper gap to get full deflection by taping a playing card in the hingeline. To get the 70 degrees i got on the elevators i needed 5 cards.
3dbandit
Began hinging the wings using the same card "trick" to maintain an even hinge gap.
