Phil.Griffin
I've printed it off too Terry. Thank you for doing that.
Good article....though I don't use RPM readings, I use the sound instead, but the process is the same otherwise.
I'm certainly no expert on Cans and Pipes, but they are all I've ever run. I've never run a stock muffler. As far as tuning the needles I do it much like you, and have had great results. I would say though that with a pipe you need to have the hi needle pretty close if you want the best performance. It's not hard, it's just not quite as forgiving as it is with a can. The big thing with a pipe is header length. I run DA's and have used their recommendations on header length and have never had a problem. Could I get better results with testing, probably, but the results I've had are good enough for me. Planebender can steer you in the right direction there.Maybe someone can chime in that has more experience than me........when using canisters or tuned pipes I know the needles are effected in some ways. How are they effected and is the tuning process any different than normal??
