All:
Been studying the quick start guide and now I am a little confused.
1. Looking at the picture of the gyro in the quick start guide, where you hook up the wires from the servo to the cortex they are lettered ABCDE and aux. then from the gyro the servo wires get connected to the other side as ABCDE.
2. the bind plug gets hooked up to position "A".
3 Position A through position D are a three pin connection. Position E is a two pin connection.
4. If the gyro is supposed to match the servo connections ABCDE why is there receiver lead going into position A?
5. Position E is a two pin slot while the rest are three pin slots.
6 After the learning process the bind plug gets removed, what goes in it's place?
Thanks for your help
Glenn
Glenn
