I think you may be forgetting about the huge drag envelope that Yak 55 is. It is much draggier than the H9 Sukhoi. Granted, the 176 may have the ass to power it. But I feel the flight envelope is going to be VERY minimal. I really feel that you are going to have to be in the power, quite heavily, just to maintain level flight, approx 2/3rds power or better.
Think about safety first and foremost. If you had taken 4# out of the tail area and another 2# out of the wings, and reduced your flying weight by the 6# mentioned, then the 176 "might" be enough to do what you want with it.
Do you really want to experiment with engine displacements and flying on an airplane of this caliber? I would really hate to see your investment and all the time you have put into this.
With an airplane this size and caliber, your best judgement should be to error on the side of caution.
I think that it is great that you are pushing the envelope and trying new things. But it should not be with this model.
Im ready for attacks. Bring it.
I appreciate your insight Chris. And I will not stand for any attacks. Insight and knowledge far outweigh anything else. Believe me, safety is "FIRST" and foremost in my mind. That being said, here are the numbers I am working with. And these I am certain you as well as others will concur with.
SD Extra 260: 3W 157CS, Falcon 32x10, static rpm: 6100, comes in at 41 pounds, 11 ounces dry. Add 50 ounces of fuel, just shy of an addition of 3 pounds. Take off weight: 44 pounds and some change. Flies stable, light and very responsive. Definitely no lack of power.
Hangar 9 3.1 meter Sukhoi: GP Evo 176, Falcon 32x11, static rpm 6600, comes in at 41 pounds, 7 ounces. Add 60 ounces of fuel, just shy of an additional 3 pounds. Take off weight: 44 pounds and less change. Flies like a rocket on rails. Rock solid, more responsive than the 260 and most absolutely not shy in the least on power.
I may not know as much as many of you out there regarding this, but I am using my two big boys to base my judgements of capabilities. Given that the Hemp Edge is just plain "BIG" and will with no doubt have a ton more drag than the 260 or the Sukhoi.
After doing a some lightening in the fuse and fresh weight this evening, (and no structural integrity was compromised) Simple removing of un-need plates from previous owner) Fuse with stabs, canopy, landing gear, tail gear, wings on minus cowl: 34 pounds. Add cowl, batts, servos and hardware including harnesses and misc. hardware: roughly 7 pounds. Add to that the 10 pounds 14 ounces of the GP 176 and pipes, weight is now at 51 pounds, 14 ounces. I plan to use a 60 ounce tank, again 3 pounds for fuel. Take off weight "SHOULD" be around just shy of 55 pounds. Now I do realize that instead of 1/4 to 3/8 throttle, (at half or above it's insane) I am using to fly the Sukhoi.... which anything above that is really not necessary, I figure I will be into at least half throttle on the Hemp. Probably more. But being much lighter than originally designed, I'm thinking it should float nicely and when the gas is mashed, I really think the big boy is going to do just fine.
The only two things that will ultimately deter me from proceeding with this is one: Balance. If it just won't balance then 'nough said. I will not add weight just to get it to balance. It would defeat my purpose completely. Two: Thrust to weight ratio. At present the GP is pumping out a whopping 127 pounds of static thrust. Add the effect of drag and the more than likely lack of authoritive control on the Aileron surfaces and that could be a factor. If the Evo will handle a 34" prop once broken in, then I may be able to overcome the second stopping point. It is really going to be all decided on the next few gallons of the 176 on the Sukhoi.
Believe me, I am not going to risk the Hempel Edge, (not to mention the safety of others) if I just don't feel good about it. Not meaning to sound like a "know it all", but after 21 years flying, I've learned one really definitive truth and it's proven itself many times over. If my gut says "NO". I won't do it.
