This weekend's work was only about 30 minutes for a small piece, but a critical piece if I want my elevators to work. I installed the plywood piece where the control horn goes on the bottom of the right elevator.
Here's the pics of cutting out the pocket and epoxying the in the plywood for the elevator control horn.
Steps I followed to do so:
1. measure the location from the LE of the elevator to get the LE of the pocket
2. Place the plywood piece in position according to the plans
3. Trace the edges of the plywood piece with a pencil or felt tip pen
4. Use a super sharp #11 Xacto knife to cut the perimeter
5. Using the Xacto knife, cut away at angles to start pulling balsa out
6. Use a Dremel tool with appropriate attachment to clean out the glue and rest of balsa down to the elevator base.
7. Clean the corners of the pocket with the Xacto knife
8. Test fit, trim as needed.
9. Test fit one more time
10. Mix up the 5 minute epoxy, slather it on 5 of the 6 sides of the plywood piece and place in the pocket. Wipe up excess epoxy while pressing and holding the plywood in position. Once epoxy starts setting and wood is not pushing out any when letting go, leave it be over night.
The next night I broke out the 220 grit sandpaper and sanded the top of the plywood to be flush with the elevator root tip.
