rcdude07
The two shall become one: pics
Here's the pics from about 2 hours of work over the weekend. As you can see I rerouted the aileron servo wire, then there was prep work to get the wing halves ready for joining, test fitting and sanding/shortening the dihedral braces, and sanding/cutting to get the wing bolt plate to fit, and drilling the holes in the wing bolt plate, then came the epoxy. I almost made a HUGE mistake while trial fitting the dihedral braces. They wouldn't fit right, and before I started cutting I realized I was trying to fit them upside down compared to the way the wing halves were sitting on the table. I had forgotten the wing halves were built upside down and were still sitting that way on the workbench. Fortunately I caught this before doing anything drastic, and when they were put in correctly, they fit right. To get the right dihedral on the wing the kit contains a large balsa block that is stood up on the table called the Wing Jig or wing root jig. The spars and the TE tabs sit flat on this and the tabs on W12 ribs sit flat on the work surface.
