3dNater
In that instance I used the stock plastic arms with the CF extensions attached. If you are going to use aluminum arms you shouldn't need CF extensions.did you use stock plastic arms attached to the carbon arms or did you use the metal round servo arms that redwing sell
to attach the arms to.?
thanks
Edit: I didn't get the whole question in my mind on the first pass lol. The round aluminum arms should work great with the CF extensions. The issue was with the connection to the servo spline stripping out.
