Yes, it's raining, and it's 2 days before Christmas and I still have some last minute shopping to do... but I had to drag it out again for some reason.
I ordered a new cowl, but I may just stick with the original... from above, you can't see the other holes that I cut for the other exhausts, and the holes aren't that big to begin with... so I'll wait until the new one comes in and take a look at how closely the colors and lines match up.  If it's a good match, I'll change it out.
I still need to install baffles, and I need to cut an air exit hole in the bottom of the fuse, since the cans will heat up quite a bit.  The batteries are moved back, so I think baffles and air exit are the only things keeping this plane on the ground.
It will be after new years before I get to any o fthat, but it's just about ready for its re-re-maiden!
That rattle you hear is the stabs shaking around... I need to put at least the bottom wings on when I do this.  Other than the stabs shaking a little, it's actually much quieter than I expected.  I like that.
