Check out the DLE-35RA
I buy mine from http://www.justmodelprops.com Falcon does not make a 19x10. Mejzlik does. I usually get those from Desert Aircraft as they are the importer. PT makes one as well. I will be trying a few of their props soon as they make some of the sizes Falcon does not and are supposed to be comparable. Jury is still out. 21x10 and 25x10 for my twins, already drilled and just waiting for weather.
http://www.espritmodel.com/pt-propellers-glowgas-carbon-fiber.aspx
I would probably just run the 19x8 as that is what Patrick runs on his DLE-35. You get the spool up and good speed. I think I have one Xoar lam 19x10 as well that I ran on my VVRC 40 to go stupid fast. Not very good for hovering with all that pitch.
3dNater
Thanks for the info... I definitely like to hover ;) I was getting 8000 rpms on the ground with the xoar 19x8. You don't think I will be over-revving the motor in flight?
I think your rpm in flight will be at 9k if you fly a long, level/descending full power line. If you use full throttle judiciously, (accelerating, uplines, punch outs, etc) then you should be good.
Plus you already have one! :D
3dNater
Yes I do already have one... :) I like the performance on it as well... the plane is much faster. The 20" prop makes post stall really nice though.
WELL... In that case... Save up for a falcon 20x7 CF for the future. I love mine on the DLE30, tons of speed, and nice post-stall propwash.
Yes, the Falcon 20x7 is a wonderful prop. The Mej 20x7 is very similar. My GT33s don't spin it with enough authority so I use the 19x8. Bigfoot has a Biela 20x6 as it just plain looks cool.
