Phil.Griffin
Excellent.. Thank you guys.
Robotech;10611 wrote: And they nailed it. One small hole was all it took. It's amazing sometimes how little it really takes to solve a seemingly large problem.
All that information is good, however, the RPM will NOT increase with a tailwind as stated in the opening statement. Wind only affects ground speed. Otherwise all of the info is very helpful. My DA 170 on RE3 pipes is only turning 6050 with a Mejzlik 28.5x12x3B
So a 4 year old thread but I'm curious, what makes rpm increase when you dive your plane towards the ground? Not a tailwind but still wind is affecting the rpms...... no?
Barrman is absolutely correct, wind only affects GROUNDSPEED. For instance at WOT going downwind your airspeed is xxx, make a 180 into the wind your AIRSPEED remains the same and RPM remains the same but your ground speed changes, but the loading on the prop is constant. In a dive your AIRSPEED increases therefore unloading the prop.When you're diving towards the ground your airspeed increases so the engine unloads a little and the RPMs go up. When you lift the nose to climb without increasing throttle, the airspeed goes down a bit which loads up the engine and so RPM's drop a little.
A headwind or tailwind wouldn't change the engine RPM, it's only airspeed that would do that.
To a lesser degree, a well designed intake can use higher airspeeds to force more air into the carburetor increasing RPM, which would be in addition to higher airspeeds unloading the prop both causing the RPMs to increase.
Think about when the engine is on the ground with zero airspeed, the RPM's are well below what the max will be in the air. That's because without any airspeed the prop has it's maximum air loads to work against so RPM is lowest for a particular throttle setting.
