thurmma
Here is my two cents on the subject. I don't know much on the two stroke side, but when I was playing with small block Chevy's, the more radical the cam, the more the engine shook. Why is this you ask? When you leave the valve train open longer to get more fuel into and out of the cylinders, you do not have the opposing compression to offset what is happening on the other side of the block, so it would stand to reason that you have an engine that does not run as smooth as one that is building compression on one side while the other side is burning fuel.
With the two strokes, the same principal applies when you start playing with the port timing. The compression does not start building until the piston is further up the cylinder. You now have mass moving further than it does in an engine that doesn't generate as much power, but runs smoother because the compression is actually slowing the mass down sooner than it does in an engine that has port timing that is designed to get more fuel in the cylinder.
One other thing to consider is, the engines that are developing the monster power, both 4 stroke and 2 stroke, generally speaking have a higher compression ratio, which will create a more violent burning of the fuel thus developing more vibration.
If I am totally off my rocker on this subject, let me know, I have a thick skin and love to learn where I am misinformed
