chetan121993
Hey guys I have a 30% TOC Extreme Yak 54, the company was TOC1 then Aviation Models, then I heard it became Pilot (but Pilot says nope) None the less, I don't have a manual for the plane. I want to get the right CG to start with so I need your help determining the correct location.
On a 35% E-TOC Yak 54 it is 8" from the leading edge at the root (so I have been told). Right now I am trying to set up battery locations and shave some weight so I need to know as much as I can about this plane.
Most of the planes I researched in the size have a AUW of 16 lbs, does that sound right to you?
Thanks for your help.
