As I had mentioned before, I will make the incidence and placement of wing bolts way easier. Well, at least, much easier for me, and in my comfort zone.
I will elaborate.
The plans and manual have it such that, on the root cap, a plywood is installed with blind nuts, and the wing is fastened to the fuselage using an 8-32 screw with a washer.
I do not like this method, not that it is bad or not worthy, but only, out of my preference. I would prefer to do it differently and in my comfort zones. The way I will do it, to me, is way easier.
OK, here it is:
I will 1st glue on the hard points in the fuselage, based on what is mentioned in the plans, and once cured, I will drill a hole from the outside in, and in an angle, which is probably 4.5 degrees off perpendicular to the fuselage side, based on Dean's measurements, which he mentioned in his thread. Then, I will assure that a drill bit can come in from opposite side to the side in question. This has to be square, and so far, I have accomplished it on both fuselages.
This is the hard point, already glued in. I am using a small drill bit, 1/8" diameter.
I then drilled all the way across to other side, and entered the hard wood thru the small 1/16th pilot hole I predrilled. now this side the hole is "square".
Here is the long drill bit out the other side. I then removed this, and came in again from this side into the opposite side, just to make both holes "in line".
Like this.
this is that long bit, and again, this is now done to all 4 holes on both Fuse #1 and #2.
the next step: I will place the wings on (which are totally untouched, nothing has been done yet), and then I will set the incidence to ZERO, and heat up the tip of the this small bit. Then I will enter the foam of the wing root by 1", and do the same for all the wings.
After this "pilot" hole is placed in the root of the wings, then I will obtain a wood dowel, that is about 1" diameter, and cut it to a 1.25" length. Then I will trace the outline of the dowel over the small hole, so that the center of the dowel will be in line with the pilot hole. Then I will core this foam out, for a 1.25" deep, and then glue in the dowel into the wing root. Then I will glue on the root cap, with the fuselage on its side. DO one by one, to make sure the root cap is flush with the fuselage side. Then I will sheet the wings so that the balsa sheeting go over the root cap. Somewhere in there, I have left out installation of the wing tube phenolic and the reinforcement of the foam with an upper and lower spar.
Ok, once the wings are sheeted and LE and TE is sanded and beveled, then I will place the wings on the fuselage, one side at a time, set my incidence to ZERO, and then, using this small drill bit, come in from opposite side, and drill into the hard point. once I am certain it is zero again, then I will leave the drill bit in the forward hole, and recheck again, then get another drill bit, and come in to the aft wing bolt hard point, drill it with the 1/8" bit 1st, recheck incidence, and then drill it with a 15/64 bit, that is long, and then install the 1/4-20 stud. then replace the wing, and do the front hard point.
Regarding the stud, i have several options, and I will list my #1 preference 1st:
1. Obtain the aluminum threaded stud, that DA used to sell. I emailed Dave, and he states, they have not manufactured them in a while, due to their machines (CNC, i imagine), being in such high production for other things. If they ever get caught up, they will whip up a batch of them bad boys, but for now, they do not have them. I have contacted Vern, at white rose, and he explained to me, that he could make them, however, it requires programming of his CNC machine, and understandably so, it would be labor intensive, and even though he has not told me, seems to me, that It would not be worth his effort to manufacture 8 or 12 of these for me. I do not blame him. For now, this seems like something I will not be getting.
2. Option 2, go to Lowes and obtain the 1/4 - 20 thread / studs, and then, glue in the nylon bushing that Tony, from Dalton aviation sells. these bushing will go into the holes made. SO now, the threads, as the wings are put in and out, will not "wallow" out the hole over time.
3. Use those studs, and glue on a aluminum or brass tube over it, that is 3/8" in length.,
#3 might be best way to go for now.
I will keep you all updated as to what happens.
