Well, I was very fortunate, I received a message from a willing experienced Carden builder, and now I got some great tips for this step. As Snoopy stated, measure twice and glue once. Well, we will measure two, three, 4 times, and so forth before we glue...
Ok, here is the end result of the conversation with Dean:
1. be sure that the F6 is tapered and then clamped in place:
2. then, use not only the phenolic but also the actual wing tube, to make the alignment of the right and left tube supports in place. This will help prevent any bend in the phenolic.
3. Then measure and glue and clamp the wing tube supports in place, however, to assure that the wing tube is square to the table /fuselage.
I used a caliper, to measure the right and left side distance to the table:
before making adjustments:
one was 94.08 mm off the table, the other side was 94.48 mm
after making adjustments and applying the glue:
the right side is 94.3 mm
the left side is 94.3 mm
I also assured that the phenolic is perpendicular to the motor box side.
Thank you Dean!
Thank you Dean!
