O
Ohio AV8TOR
exeter_acres;4591 wrote: Jase doing a little MXS Flying
I was so glad to see this video and have Jase bring to life what this plane is capable of. I so enjoy his flying .
Ohio AV8TOR;4204 wrote: Wow really nice touch having a plastic guide tube in a rear bulkheads for the rudder cables to pass through.
On mine I just took the template for the DLE-35, and used the bottom two holes. They were the same width as the DA-35, then flipped the template and marked the same two holes for the top. On the dle-35 the bottom two are the same spacing as for a da-35, but the top two are 5mm narrower. So just flip the template, and you can use it to mark all 4. Worked perfect on my MXS.Spdstr280Z;6938 wrote: Yep, I just noticed those too ! I got distracted and have not done much on mine, you are way ahead. The VVRC 40 looks perfect in there ! I have a DA-35, and am just glad the lower intake does not have to be cut all the way out. The stock 35 standoffs look like they will be perfect, but I still have to trim the cowl to be sure. I was frustrated for a minute that neither EF or DA has a template for the 35, but eventually got off my lazy ass and made my own.
Jason
Spdstr280Z;209 wrote: Will post up some pics of the assembly of the Extreme Flight 83 inch MXS, who else has one ? I'll be going with a DA-35 still trying to decide muffler or pipes....
Great idea for a twin.Ohio AV8TOR;4410 wrote: I am glad how the small yogurt cups worked for cooling baffles. The heads of the VVRC40 are slightly inward to catch all of the air going through. These cups fit the back side of the inlets. All it took was cutting some angle to it to direct the air over the complete head.
What are you going to do with that new DA50 you are going to win in a few days? :smile-new:AKfreak;12726 wrote: Just got my ARF, and going to run a DA50. I cant wait to start, but still collecting parts. I will say the only thing I wish was different was the cowl. I wish it had a cowl ring like the other planes I own.
ryan_m;12890 wrote: You must be confused, I'm winning that DA!!
Just so I can stuff it in my MXS![]()
