Yes it does. Jody recommended once that the passages in the carb were the needles seat can become restricted with debris. Might be helpful to remove both needles and disassemble carb down to the block and blow out all passages and clean every thing. I do not think the needles are damaged but check to see if they are scored around their tapers where they seat in the carb.
May be Jody will chime in here. Damaged seats normally let every thing stay rich.
Finnaly remembered to tach the eme 35 today 20x7 falcon carbon and a dla 32 wrap around Pitts I think we're around 1500feet 0 c out today and I got 7450 on it today. Hauls the 30cc areoplus mxsr around pretty easy
Is that with stock exhaust? My buddies planes that he took to Florida using a different Pitts muffler is up around 7800. As I said my muffler is meant for a smaller motor. And it's a little rich new motor. And for 400 rpm I will pay 200$ less lolol
Even with the difference in power which should be expected,
no biggie if it, "Hauls the 30cc areoplus mxsr around pretty easy."
For "some", the price point is all the difference between havin fun, or not...
Most planes at our field anyway, have way more power than they need for sure.
