esc for 70" extra
Bushwacker
3DRCF Moderator
It's all good brother. Remember we already discussed the different options for my motor. My final decision was a Mezon 90. I was going to do the 130 HV, but after talking with Ken he assured me the the 90 would be enough. Said I will probably only be pulling about 77 amps or so.
It would be great for someone to follow up with experience regarding the ZTW ESC's...I've always liked these ESCs but I'd like to hear from someone who has tried it and found success in some of the problem configurations.
Bushwacker
3DRCF Moderator
All it took to correct my problem was a amplified wire. Problem solved. Signal was too weak from the ESC to the RX. Humm thought I posted about this. Well at any rate there it is my fix. :banana:
:veryshocked: :flyer: Now my Vyper runs like a RAPED APE :flyer: :veryshocked:
AWESOME, glad you figured it out....!!
Video or it didn't happen!!!!
Bushwacker
3DRCF Moderator
I would give you a vid of it flying, but I have to get some new wheels and an axle for it. However here's this for some proof. My son was a bit scared of it, so he went slow. I should do another one. BooYa!
[video=youtube;ZawFUSa0oxE]https://www.youtube.com/watch?v=ZawFUSa0oxE[/video]
I haven't used the ZTW, but I've had good luck with the YEP esc's which are YGE clones and they work great.
My A60-6XS had several ESCs. Started with castle ICE 100. It got smoked when trying to use the brake function. Then I used a Hobbywing 100A platinum which worked fine. The next iteration had a Gecko 155A, but the BEC failed and fried all my servos.
The last iteration I went back to a castle ICE 100 on V3.27 and tried 7s with the motor. A bearing was going bad, so I replaced the motor with a 4330-400 which now has a Mezon 120 in it.
The Mezon 120s are not as expensive as the 90 and 130 HV ones and with the coupon codes can be had for around $200 shipped.
I have also had good experience with the two Hobbywing ESCs I have run and recently sold that platinum. Check out their V3.
