YellowJacketsRC
This looks really really cool. But I am still thinking of a pilot which will require d if fervent picture
If you do not seal your gaps there is no time like the present and make this a part of every build. I do this a little different than some and I not only find it easier it is so cheep. In the past I have used Blenderm tape, Monocote and Ultracoat but I am telling you clear packing tape is the way to go. It is so clear it makes no difference with whatever coloring scheme you use. Something else I found is you do not have to do it all in one piece. I cut the tape in about 8" or so length which is so much easier to handle. I am using 2" wide here. Lay the wing on the table letting the aileron fall. I place the tape on the aileron trying not to let it touch the wing. Press in on your finger to get it sealed right down into the gap then allow it to touch the wing and rub it down. Take an Xacto knife and with ever the slightest pressure slide the blade to cut the tape. I so it about 1/16" down from the top of the wing. The pressure I use is only enough to score the tape not cut it and peal it back and off. I use the remaining cut off for the next strip and I overlap it 1/4" or less. Do this to finish the full gap and I take a plastic pen cap and rub it down to help work out any line. It is totally invisible and I have never developed a tear. I do this on the bottom surfaces.
Yes the slide on the right is finished so you can see how clear it is.
Just got 8 flights on mine today. What a blast! Here's a shot of my cockpit too.
Is that the one Ray came up with?
GYRO;64651 Is that the one Ray came up with?[/QUOTE said:Actually... It's the one I came up with for Ray.
I did one for my beast that he saw and we tweaked the file before I got my Laser.
I'm editing some video from yesterday with the Cortex. VERY fun! I'll post a link when it's done uploading.
